AHC LC200 front valve replacement
Kelso Scotland
I've managed to get two complete front suspension accumulator assemblies originally just for the new globes. If I swap out the entire assembly including the valve will the ECU be able to recognise the valve position or will I have to calibrate the system ?
It’s uncharted territory. Just follow the fsm on install. I suspect a couple up down cycles, maybe a 2nd bleed and you’ll be ready to roll.
Indeed; uncharted waters. Suspect your right. it seems it just receives open/close from ECU. I don't think there is anything wrong with the one on the vehicle but
having come across two new complete assemblies at a very good price makes sense to swap the values out for new.
