Does anyone have an actual picture of what fitting to bleed on the AHC actuators? The diagram I have is pretty vague. Got two cans of OEM AHC fluid and am ready to go.
no need to use a vacuum bleeder on the globes or actuator. read the FAQ on AHC bleeding and bleed one globe at a time. keep the truck in Normal height, and bleed it to low at each corner using the weight of the vehicle.
to see where you need to bleed them, pop your head under the truck and look for a little rubber cap that is covering the bleed valve. super easy to do just be patient and careful if you still have your running boards on.
Maybe I wasn't clear but this is to remove the old fluid from the reservoir. This will ensure you have fresh fluid going through the system when bleeding...
