Yep, just finished the birf repack on the new 97. I was surprised how nice the birf grease was - kinda sloppy and whipped looking, but not much oil contamination from the axle seals compared to my 93 at around 90k. Both axle seals were in very nice shape, owing to the fact that I could barely see a wear pattern on them. Both were worn *faintly* at the 12 O'clock position, but these axles were clearly running almost in the center of the seals - the key to long birfield maintenance cycles.
Also found an inner wheel bearing showing some distress, and its race had clearly been hammered in three spots. Strange wear pattern that looked like only half the race and bearings were touching each other. Wonder if this was the slight wander the truck had? I'll find out tomorrow on the test drive.
The knuckle bearings were fine, but I replaced them anyhow so I don't have to open things up for another 100,000 or so.
This subject has been beaten to death, but I have a couple comments.
First, John Davis mentioned in his rebuild that the ABS sensor O rings were looking kinda sad. Mine were too, so if anyone can find a source for the correct size of these it would be great. Don't forget to liberally grease these sensors before reinstalling them so the O rings aren't torn.
Second, if you're going to wheel your rig in wet conditions, consider liberally working fresh grease into the felt seal before buttoning it up. They'll get a little saturated, but it may take months for them to be waterproof.
Third, consider greasing the entire inner axle before inserting it to prevent damage to the new axle seal. Yes, you'll have a half teaspoon of contamination in the front diff, but with the high front diff oil volume it will hardly be noted.
Fourth, the question if oil pumped in the square plug gets to the birf has been answered - yes it will! I put a half tube of fresh grease in there a few thousand miles ago on someone's suggestion (anyone remember who - Rich?) and it had indeed been churned into the birf. Not sure how much of this successful churn was because the existing grease had been thinned and undoubtedly allowed more turbulence in the knuckle than fresher uncontaminated grease might have. So, an interesting find.
So, at 138,000 everything looked pretty solid in there except for a bearing.
While it was apart, I sanded the front rotors to take the gloss off. I also elevated the front diff vent. Anyone who's interested in prolonging their birf health has got to do this simple mod. For fun, I timed this and it took me 3 minutes, including installing 2 zip ties with the wheel off. Drop the new hose down from the engine bay, lean in the wheel well with pliers and pull the spring clamp off the existing hose after pulling it off the nipple. New hose attached. 1 zip tie to the old hose. Stand up and cut the hose up in the engine bay to the preferred length. 1 zip tie in the engine bay next to battery box. Done. I'll get a cheap fuel filter on it later to prevent bugs, dirt from getting in.
So, after a quick spin around the block, the 97 joins the 93 in having birf balls covered in purple Amsoil...
DougM
DougM
