Aftermarket Tacoma exhaust manifolds?
vtcruiser60
So I noticed a crack in the exhaust manifold for my 2.7 L 1996 Tacoma. Toyota parts sells replacements for $219, aftermarket manifolds range from $60-95. Are these aftermarkets any good?
Any suggestions?
bump...
Seriously...is there any experience with this on the board?
I bought an aftermarket manifold from Bishops, in Dallas. Had to grind the front edge of its flange before installing. Other than that it fit well and is a heavier casting than factory.
calamaridog said:
Try LCE or Downey...
Don't get Downey..They crack worse than stock. NWOR makes one that works better for low end grunt and the LCE is built more for mid-high range power.
I got a stock manifold off a guy that swaped a header onto his 01. 01 and up Toyota changed designs and went to what I call a mini header. it all welded tube not the cast junk that came on the 00-96's.
