My '99 LX has about 121K on it, I've just been too busy to set aside what I hope will only take one full weekend to do the 120K Service plus maybe a few other items.
One issue that first happened wheeling the other day, I was going up a steep incline and at some point the engine died during the ascent or perhaps when I stopped making forward progress (guess I need some air lockers). I'm not sure exactly when it cut out but it happened on two separate occasions. I'm a little concerned. Any ideas on this?
These are the things I'm planning on doing as far as the 120k. I'd like to get to the bottom of the engine cutting out at the same time.
Physical
- AHC Fluid
- AC Filter
- Brake Fluid
- Spark Plugs
- Lube DS, torque bolts
- Lube front axle shaft bushings (Saw recent thread, will order Slee tool)
- Repack Front Wheel bearings
- Change Diff Oil
- Change TC Oil
- Clean MAF & TB
- Trans Fluid
Check
- Check Fuel System
- Inspect Belts
- Inspect R&P Steering (How?)
- Inspect Charcoal Canister????
- Inspect Valve Clearance
- Inspect Steering Linkage and Boots
- Inspect Axle Shaft Boots
- Inspect Ball Joints and Dust Covers (What?)
Physical
- AHC Fluid
- AC Filter
- Brake Fluid
- Spark Plugs
- Change Diff Oil
- Change TC Oil
- Clean MAF & TB
- Trans Fluid
Check
- Check Fuel System
- Inspect Belts
