I'm getting ready to drop the transfer case in the 4Runner to reseal it, and have a general question.
The transfer case housing is aluminum. It has 3 internal holes/paths for shift rods; however my configuration only uses 2 of the shift rods. I want to plug the 3rd one.
This 3rd one allows gear oil to pass through to where it can get in the actuator. My thinking is if I plug this hole, and use my new seals on the other 2 shift rods, I should mitigate any leaks for a long long while.
Kind of been casually looking for a plug. The hole accepts a 15mm plug. I am unsure what material to use in this application - steel, brass, aluminum, or ? It'll see heat, gear oil, and the back side will be dry (so corrosion is a concern). Of course, I'll do something to prevent it from coming out if I use a freeze plug; alternatively, might an expansion plug work? (and virtually eliminate it coming out and getting ground to bits; I worry about the neoprene/rubber though)
Thoughts from those smarter than I would be appreciated.
Ramon
