Hey guys, thought I'd share the build for my 2000 Toyota Land Cruiser with the forum in exchange for all the reference information ih8mud provided along the way. Turned out to be a decent amount of work due to some snags along the way, but overall very happy with the result! I did the work in two stages, replacing the head unit and door speakers (bypassing the factory amp) about 18 months ago, and adding a 5 channel amplifier and dual 8" subs in a custom sealed enclosure to the system over Memorial Day.
I went with pretty entry-level gear due to budget constraints (lots of other projects I have in the works that need my money and time, haha) and wattage limitations. Didn't want to pull over about 40A of max current due to being limited by the stock 100A alternator. I also wanted to preserve power for the AC system in California heat. So I put together a ~700w system based on the Infinity Kappa 5 5 channel amplifier, Infinity component front door speakers, Infinity coaxial rear door speakers, and dual JBL 8" subs in the back, all controlled by a single DIN Kenwood digital media head unit.
I started under the hood doing the "big 3" with 1/0 cable for the grounds (had some spare 1/0 cable to use) and 2awg for the alternator power lead. This alone increased system voltage by almost .4v at the battery terminals.
Then I went ahead and routed 12v+ through the engine bay. In this image it's the black loomed cable running across the top of the firewall. There was an existing grommet I found with sufficient room to run the cable through the firewall, which was a big help.
Loomed 4awg amp power cable connecting the battery terminal to the fuse location, which is mounted into the sheetmetal support structure. I didn't have enough loom for the entire run, so I protected the most visible/heat exposed parts of the cable and will do the rest later.
When the under hood wiring was done my friends and I began work on the drawer setup/subwoofer enclosure. I decided to use 2 8" subwoofers to fit into my existing drawer system in sealed enclosures. The unpainted plywood panels mark the sub enclosures, with a storage compartment w/ lid in between.
Cont. below due to image limit.
