access panel to fuel tank fj60 rthn
O-H-I-O
I am in the process of dropping my fuel tank, I have the spare tire cross member off, but the two screws holding down the access panel in the cargo area are not budging. Am I right in assuming I need to get in there prior to dropping the tank in order to disconnect the wiring to the pump, or can I drop the tank and disconnect this stuff once it has been lowered a bit? Surprisingly the hoses from quarter panel came off pretty easily, I think the fuel tank recall has been done at some point in the past as I was expecting of have to cut off the hoses.
I'm guessing there's not much difference between the two, other than a high pressure fitting and a couple extra wires for the pump. The link was more about the sway bars, but I don't know if an '87 60 had sway bars.
Thanks, thought it was best to ask before I started lowering it. This is the first weekend in a number of months that my wife did not have to work which gets my 2yr old daughter out of my hair. No rear sway bar to contend with, I believe only the 62s came with those. Oh, and if I am not using the stock spare tire carrier is it alright to ditch the crossmember I took off? Does it provide strength to the frame? Maybe I should just clean it up and reinstall, it would provide some protection to the bottom of the fuel tank. :beer:
Spare tire hanger adds nothing to the structure of the frame, not a bad thought on the gas tank protection though. Make sure you lube up the bolts with anti-sieze, next time (or any time) you take it off it'll be that much easier.
Trust me, the bolts did not play nice so I used a cut off wheel to remove them. My pos hf grinder just crapped out on me. The chock pin broke, I was about to move on to cutting of the rear exhaust, drop the tanke and then remove rear the axle. Guess that will have to wait until tomorrow.
