AC no workie...'94FZJ
State of Limbo
Hey guys, I need some advice for a novice.
Until yesterday, my AC was great. Now after an install of SLEE wiring harnessess, I don't have any AC. I have done a search, and find on atleast earlier models, there is a 'pressure switch' behind the left headlight area that I should check. This so happens to be where the harnessess are located so I think I am on the right track already.
2 probs:
1> being the novice:o that I am, I don't know exactly what I am looking for in terms of ' how a pressure switch ' looks although everything I see looks connected, and
2> the owners manual says its a 15amp fuse, but the fuse cover diagram at DS left knee says its a 10amp..whats this about?
Thanks for any advice,
Sweating in UT ,
Be more specific on AC no workie. Does the compressor "kick in" while the AC is running? There is another fuse box location in the engine bay behind the battery.
Soory about that !:doh:
Compressor no kickie !...just hot air, AC button does light up.
Hummm. You might of disconnected something huh? The pressure switch is located in front of the battery. It is an in line switch with (2 wires?) that connects to the AC drier (The thing with the sight glass). Also check the wire above the compressor.
