Did some work on my hundy last week: timing belt, bearings of all sorts, valve cover gaskets and radiator replaced. I also replaced the bearing for the AC pulley. After butttoning all up, everything is great, but my AC clutch won't engage, and I have the blinking light indicating some kind of lockout.
Local shop here in Cary that I trust tells me "they can't get the diagnostic past the lockout" and are advising new compressor. Only issue, is this thing ran fine two weeks ago, until I evidently screwed something up. All I did was unplug the compressor, remove the clutch and pulley, and install a new bearing. (all plugs are back in correctly- was hoping that was it, but it's not!)
Is it possible the local shop doesn't have the right diagnositc tool, and this problem is as simple as clearing a code? At this point, I just made an appt at Mr. T for another diagnostic before I shell out $1100 on new compressor install. Any advice is welcomed, including someone you trust locally. AC stuff is way outta my league, but i'm addicted to AC, even in winter!
