Abs sensor? (1 Viewer)
Idaho-‘Does any other place matter?
Drove the truck today and had a couple lights turn on:
VSC
Skid(what’s that one called? )
4hi
4lo
ABS
This is on an 08 tundra 4wd with 148k. Before I noticed the flashing I noticed it was acting like it was on ice and kicking in the traction control. I was on perfectly dry pavement, no potholes or gravel. This only happened from a stand still. Once above 10mph, it drove normal. After a couple more stops around town the dash started lighting up. 4hi/lo flash at one speed and skid(?) flashes at another. VSC and ABS stay on steady. Truck drives fine. When I got home and needed 4wd, I had to cycle the ignition to reset the lights in order to switch to 4hi. Light quickly came back.
Sounds like abs sensor or wiring, right? I hooked my scanner up and it’s not throwing any trouble codes. Anyone have anything else I should look at tomorrow?
No my scanner doesn’t seem to get anything but Ecm stuff. Took it to a tire shop and they read the code for me- Right rear. The sensor comes today and the wiring harness comes in on Thursday. We’ll see..
Resolution- the wiring harness on the rear axle is replaced and everything is back to working. Thanks for the help and hopefully this helps someone else.
