kcjaz
Noticed the retaining clip on the ABS sensor wire is missing. Anyone one know the P/N? I can’t find it.
thanks. That's all I could find too. I did look at the other side. Didn't think to look for a number on it. Its pretty small so I doubt it will have a number. Zip tie may work. OEM zip tie of course...I can only find the whole wire as an assembly including the brackets and clips in the diagrams.. maybe check the one on the other side for a molded part number.
Someone with more experience may be more able to get into the specifics of the diagrams and find the clip.. but it's not obvious.
It may be the same scheme that they use on their harness connectors where there is a six digit code, but you combine that with a standard other six digits (for all connectors) and make a complete part number. Plus they can mold those numbers really, really small.thanks. That's all I could find too. I did look at the other side. Didn't think to look for a number on it. Its pretty small so I doubt it will have a number. Zip tie may work. OEM zip tie of course...
So I took a look at the other side. Its an OEM zip tie LOLIt may be the same scheme that they use on their harness connectors where there is a six digit code, but you combine that with a standard other six digits (for all connectors) and make a complete part number. Plus they can mold those numbers really, really small.
But yeah, OEM zip-tie would probably work well too.
Hah.. perfect!
