Hey guys,
Dealing with an ABS pump issues on my '99 LX470 with 253k on the odometer. I'm experiencing all the issues people have posted about an ABS pump failure. (red) Brake light and ABS light came on with a buzzer. Pulled into the grocery store parking lot and as soon as I pulled into a parking spot the pedal just about went to the floor. I still have minimal braking at the bottom of the pedal travel.
I popped the hood and applied pressure to the brake pedal with my left hand on the abs motor, and it would not come on. I can hear the "ABS MTR1" relay clicking on and off, but the pump does not come on. My buddy with an LX470 came to give me a hand and we swapped the relay to test it. Works fine in his truck and his relay does not work in mine.
I did the master cylinder rebuild about 2 weeks ago. Opened the bleeder screw about 4 times on each caliber to bleed the brakes. Have had awesome brakes ever since the rebuild.
I've concluded the ABS pump will not come on for these possible reasons:
1. ABS pump is fried
2. There is air in the system and the pump will not come on (I've read this before on this forum where mud members have asked if there is a sensor that keeps the abs pump from coming on when there's air in there. The reason this makes sense is because when i first bled the brakes and clearly had air in the system, i got the same lights and buzzer on the dash)
3. Electrical connections to the ABS pump are corroded
A couple questions for anyone that has the time:
1. Does anyone have some insight they can share before I jump on a $2000 ABS pump replacement?
2. Can anyone confirm that if there's air in the system, the ABS pump will not turn on? I really think this could be it. The pump never screeched at me or made any noise. It was working great after i replace the master cylinder.
3. this kind of goes along with #2, but why would the abs light, (red) brake light and buzzer/alarm come on when i went to bleed the brakes (after reinstalling the master cylinder assembly)? Is there a sensor that recognizes there's air in the system?
