My abs pump motor has failed, and my truck is unusable until it is repaired. I have to questions for those who may know something about this...
1) this is a very expensive repair as the motor is part of a greater abs assembly or assemblies. What is the best decision for replacing this motor and/or other abs components in the area? I'm thinking these parts are so expensive that I would prefer to have a long term brake repair and do not have to buy some the same parts again if another area of the abs fails?
2)I have a used abs unit with working pump motor from a lx470, it and the resevoir look identical and mount identical, but the abs unit / chassis it mounts to appears extremely similar yet it does have an additional port for hydrolic fluid and an electrical connection for a slightly more advanced breaking system. Both are likely for atrac. Does anyone know if this motor and resevoir will work in a UZJ100 without atrac. It has different numbers stamped on it but it looks identical. Do you think it will provide different pressure when the abs unit is almost the same. If the pressure is different will it really matter?
