Wanted ABS pump for 95 FZJ80
alabama
  1. 80 Series
Birmingham, Alabama United States
Looking for a working ABS pump for my 1995 Toyota Land Cruiser FZJ80. Toyota Part #44510-60010
I have several. $35 plus actual shipping.
I wouldn't know until I went to UPS. USPS flat rate medium is $19.30. I think it would fit in a medium box.
That sounds great. I was just doing some reading about checking the ground and the relay..I’m going to take a couple days and try to make sure I’m not missing something and I’ll follow up with you then. Have you ever installed one of these…sounds like bleeding them is a process. Thanks again
Yes. I've installed many. I generally hook them up to the master and leave the other line cracked open to bleed them.
Ok I’ve been able to verify my pump is bad. I have a mechanic friend that’s going to help me install..one caution he gave is that he’s installed many pumps that have been laying around that maybe weren’t locked up before he installed them but were locked up after sitting with lines open. Is there any way to verify a pump works before installing? I’d like to keep the ABS vs deleting. Do you know the condition of your pumps? Thanks.
Anything is possible. They were removed from operational vehicles and stored on a shelf in a dry clean environment.
