ABS issue
Tonopah
My ABS and traction control lights are on. I scanned with AutoEnginuity and have these codes
C0205 Left front sensor malfunction
C1223 abs malfunction
I have replaced the left front sensor reset the codes drove around about 30 miles
These codes keep coming back.
Any tips? Wiring looks good.
Could I have a bad new sensor
Thanks
Thanks
just because the wiring looks good doesnt mean it is. need to shoot continuity of the wiring to make sure its good
ya that was my next thing to do, just wanted to throw my issue out there. incase I was missing something
i had a bad front right. put new sensor same thing. had a bad wire. checked continuity on the wires and didnt have any. pulled the abs wire off and really looked at it and found a kinda bad spot and it had corroded copper so respliced it and havent had any issue since. been a year
I found my issue over the weekend, after replacing the sensor with no luck I followed the wire back and found it broken off at the plug.
disassembled and soldered in a length of similar gauge wire, reset everything with Autoenginuty = no more ABS or VSC lights.
