ABC fluid level above max line
Black Hills, SD
I bled my ahc fluid about three months ago, and fluid level was right below max when the 100 was turned off.
Tonight doing some work on the 100 I noticed the fluid level 4 marks above max. However, the height of the 100 looks normal. What would cause this fluctuation in the fluid level?
I placed the vehicle in high mode to check the results and the fluid dropped to the min line. When I put it back in neutral mode the fluid was right at the max line. So not sure what would have caused it to be four marks above the high mark in neutral previously...odd:meh:
It takes about 30 seconds after a raise cycle for pressures/fluid volumes to stabilize in the height accumulator so you possibly were watching levels mid cycle initially. Its when fluid starts mysteriously disappearing you need to be concerned.
Thanks as always PADDO!
