Hi, hoping I'm posting in the right place. Basically I have a problem with AC working I can jump the compressor and fridge works ice cold.
Rhd based in New Zealand
A/C was Regassed yesterday
Truck started as a 1992 1hdt auto, have swapped to a 24v manual over the years which included a later model 1hdft FULL WIRING LOOM. Engine, body ect
I have the DD A/C amp in the truck at the moment which I'm unsure if it's for only the dual A/C trucks as in front/ rear cool. As mine is a 92 Jap import it only has front and fridge.
So question is do I need the DS ac amp or would the DD amp be fine. I'm sure the front ac and fridge would still work off it regardless if the rear ac switch was there or not.
Things I've tried
Testing power to compressor -nil (0 volts)
Testing power to Amp across all wires 12.4 volts on 3 of them ( I don't have a ewd to get the pin outs)
Testing the ac switch next to battery/headlight 12.4 volts
Tried a different Ac/heater box wiring loom with relays attached still no power to compressor.
I've also spent a few hours in the garage on my phone trying to search the forums for a answer to no avail.
Things I've tried
