Hi so the other day I was near the front of my 2000 landcruiser and heard a high pitch squeal coming from the electric fan in front of the condensor. This got me looking into it. I tried to spin the fan when the engine was off and it spins but stops quickly. It doesn't freewheel like other cars I have owned. I disconnected the plug at the harness at the fan and jumped 12 volts into it and reconfirmed the noise and what appears to be some tightness to the fan rotation. I checked the plug witht the a.c on both front and rear at full cold and did not see 12 volts. I know the fan is only triggered when a certain pressure is met in the high pressure switch but I don't know what usually has to happen for that fan to come on. Relay and fuse are good. Questions are does anyone elses electric condensor fan freewheel when spinning the blades by hand. You have to do this by reaching in between the grille and the fan and sticking a pen in there to catch one of the blades. Of course with everything turned off. Other question is what condition triggers that fan. I don't want to replace the fan if there is nothing wrong with it. Has anyone looked into this? Again this is the small electric fan in front of the a c condensor. Thanks. By the way the a.c. is ice cold.
