A/C condenser fan doesn't turn/spin
GE
Website
www.carstereocode.com
2006 / GX470
Air Conditioning condenser fan (CDS fan) doesn't turn/spin when AC is ON.
Question #1 - CDS fan must be always ON when AC is ON?
Question #2 - If the answer to the Question#1 is false, then when it turns ON?
Preface:
- Air Conditioning works fine, checked for leaks, refrigerant is added, pressure is OK, blows cold air both front/rear;
- CDS fan is fine, spins, checked by connecting 12V / Ground of battery;
- Pressure switch is OK, but we do not care about it (see below);
- Condenser fan (CDS fan) and compressor Magnetic clutch (MG CLT) relays are fine, checked.
- Fuse 20A CDS FAN, checked and OK;
Now please see the diagram:
- I have shortened pressure switch pins for testing purposes, in order to exclude its influence in CDS fan switching;
- When compressor turns ON, 12V on CDS Fan relay PIN1 against battery ground, PIN2 - 0V against battery ground - CDS fan DOESN'T SPIN.
You would think there is cut somewhere between CDS Fan relay PIN2 and ground, no I grounded it using extra cable directly, but fan still DOESN'T SPIN.
- It spins only when I manually shorten CDS Fan relay PIN5 and PIN3, but this is obvious...
Please, help to understand what is the problem and how it works!
2006 / GX470
Preface:
Mine is not on all the time either. I think it only kicks on when extra cooling is needed. It’s intermittent.
1 year ago non-Toyota "refrigerant add" service guy told me that this is not normal, CDS fan should spin when compressor kicks on...
I went then to Toyota service, where official trained guy checked the fan the following way - he forced to stop by hand BIG engine fan, thus making some overheating and asked to start the car - in a few seconds engine started CDS fan has also started spinning - he said all is fine... the system is designed like that... CDS fan is controlled by refrigerant pressure (switch) and temperature...
Yesterday another non-Toyota "refrigerant add" guy told me - it should spin...
So, to whom we trust?
You all know noticeable A/C performance drop when car is in idle and not moving, that is why I have doubts
