Wanted A/C Compressor Mounting Bracket and 3 Groove Pulley
Sydney
Hi guys,
I'm hunting an a/c compressor (and power steering pump) mounting bracket along with a 3 groove pulley from a 2F.
Happy to pay some decent money if you have them.
Thanks,
Mark
what year is the 2F? the 79 and later ones have holes for the OEM PS mount, the older ones do not and you'll want to talk to Georg about his Bill Dory bracket
Yes, it’s the combo mount that supports both the a/c compressor and the p/s pump that I’m after. AFAIK, these we’re produced between 1979 and 1980 on FJ55’s and from 1980 - 1987 on FJ60’s with a 2F Engine.
There isn’t an F/2F combo a/c compressor mount that has provisons for power steering mounting too. Alternator sat above a/c compressor on 2f’s. No F motors with power steering.
The a/c and p/s were on opposite sides of engine for 2f.
3fe had them on the same side but completely different setup. Worth seeing it if will work though.
The fj60 crank pulley is worth sourcing. Better than trying to find a stock Fj55 with A/c pulley.
Hi Brett, here's a pic of a 2F with the a/c and p/s on the same side.
you need the REST OF WORLD right side PS bracket and a/c comp mount. you will need to source it from a 60 with a 2F or as Brett said, the bracket will not be tall enough...if you wanted to rearrange where everything was in the engine bay, then you could source the US motor mount, a/c mount and alternator mount- all right side accessories. then get the Bill Dory bracket to put a Saginaw pump on the left side motor mount bracket. I bet you find what you want closer to home tho...HTH
