A/C blows hot on one side. Just tested the actuartors
Yonkers, NY (Finland now)
Hey everyone,
So the 2007 Land Cruiser with a 3.0 D4D blows hot air on my drivers side. It blows cold on the passenger side. Had it evacuated and filled, held vacuum for 21 mins, etc.. I just cleaned the A/C filter which was clogged. Took the panels off to see if the actuarors were working. Yes they are... Any thoughts please?? Thank you, Graham
i'm having the same issue on my GX470. i cannot figure this out to save my life. :(
What panels do you take off to see the actuators? Someone told me to check the actuators behind the glove box. Have you checked there? And where is the AC filter?
The filter is in/behind the glove box.
I also have this issue. It will eventually get cold but it takes forever. The passenger side blows ice cold right away... So is it low on gas or is it an actuator??
Sorry for my delay. The small pipe that runs near the battery had a pin hole leak on the bottom (invisible side). We found it using Nitrogen in the system. Thanks all!
