1999 Toyota Tacoma SAS
Basics:
-extended cab
-V6
-automatic
-black exterior
-tan interior
-136,XXX miles
Body:
-bed bobbed 9"
-some rock rash to bedsides, rh x-cab, and rf fender (could be fixed with relative ease)
-safari snorkle to protect exposed air intake tube in rf fenderwell
-custom front bumper and winch mount
-front frame rail plated inside and out, from front of frame rail all the way back to the first body mount
-rear frame rails boxed AND plated
Front axle:
-Dana 44 (1980 Wagoneer)
-Yukon chromoly axles
-Yukon Superjoints
-Yukon Grizzly locker
-Yukon 5.38 gears
-Yukon master install kit
-Stage 8 X-Locks
-Ruff Stuff Specialties diff cover
-Lube Locker front diff gasket
-Mad 4wd outer axle seals
-North West Fab "tall" steering arms
-PSC hydro-assist (ram, ps pump, resi)
-ported IFS box
-Warn premium lockouts
-all new bearings and seals
-all new calipers, pads, rotors
Front Suspension:
-Rancho RS44044 leaf springs
-new Rancho replacement poly bushings
-Sky Offroad Designs frenched shackles
-14" Bilstein 5125 shocks
Rear axle:
-stock Toyota e-locker
-Yukon 5.29 gears
Rear Suspension:
-Deaver 9-leaf spring packs
-extended shackles and new bushings
Wheels/Tires:
-15" Wheelers steel wheels with 4" backspace
-Super Swamper TSL tires, 36x12.50x15
-full size spare on the exact same rim (both brand new)
-4 main tires have been grooved, spare has not
-all 5 tires have Dyna Bead balancing beads installed and, YES, they do work well
Misc:
-all ABS components removed
-new factory non-ABS prebent brake lines replaced ABS lines
-all new braided/sleeved flex lines from G&J Aircraft, front and rear
-all new hard lines on rear axle
-extra set of stock front axles with Spicer joints (not installed)
-custom front and rear shock hoops/mounts
-peaked and tuned Uniden Pro510XL cb
-Wilson 4' antenna
-custom transmission/transfer case cross-member
Pics available upon request. Best to contact me via email at jester_motorsports @ yahoo . com
$11,000 OBO
Basics:
-extended cab
-V6
-automatic
-black exterior
-tan interior
-136,XXX miles
Body:
-bed bobbed 9"
Front axle:
-Yukon Superjoints
-Yukon 5.38 gears
-Stage 8 X-Locks
-ported IFS box
Front Suspension:
Rear axle:
-Yukon 5.29 gears
Rear Suspension:
Wheels/Tires:
Misc:
-Wilson 4' antenna
$11,000 OBO
