99 lx starter contacts
Humboldt
What's up fellow cruiser enthusiasts? This is my second post on this forum and I wouldn't be asking this question if I would have found the answer in the wealth of info that I have been studying for days on the subject of starter contacts replacement. I'm going to take this task on myself. This will actually be the first time I have ever really wrenched on a vehicle. A couple oil changes here and there and I used to do tires and brakes when I was a kid, but that's it. Ok, so here's the deal. I was reading on another thread where this topic has already been beaten to death and someone had brought up the fact that a small wooden block (20x37x40 mm to be exact) is needed along with a press capable of putting 981 N of force onto the block(which is being pressed onto the contact plate.). Now, in all of the step by step instruction threads that I have read or youtube videos I've watched, this has never been mentioned. Is it absolutely necessary? If so, I'm wondering if when I reach this step can I take the starter and my wooden block down to a mechanic with the FSM and they will oblige me? I've got the sockets and torque wrench but what the hell will I ever do with a press, except use every 100k when my contacts take a poop. I've attached a pic if anyone can take a look at this and maybe, hopefully, enlighten this grateful noob. Thank you so much.
Just did this and I didnt need a press or wood block. Im guessing you couldnt find your answer because nobody else has needed one either. This thread from the faq should be about all the guidance you need: https://forum.ih8mud.com/100-series...lacing-100-series-98-up-starter-contacts.html
Really not a difficult job, you just need to be able to take the top of the engine apart and put it all back together the way it was. I would say the hardest/most frustrating part was getting those darn injectors unplugged. Good luck, and take pride in the fact you rebuilt your own starter instead of taking it in and spending hundreds to have a new one installed.
All I needed was hand tools, it was a piece of cake. The work is in reaching the starter for sure. Once you get to it the contact swap is self explanatory. You do need to drain some coolant and you do need to be careful to keep the intake runners clean of any new debris.
Just did this and I didnt need a press or wood block. Im guessing you couldnt find your answer because nobody else has needed one either. This thread from the faq should be about all the guidance you need: https://forum.ih8mud.com/100-series-cruisers/9117-procedure-replacing-100-series-98-up-starter-contacts.html Really not a difficult job, you just need to be able to take the top of the engine apart and put it all back together the way it was. I would say the hardest/most frustrating part was getting those darn injectors unplugged. Good luck, and take pride in the fact you rebuilt your own starter instead of taking it in and spending hundreds to have a new one installed.
Sweet! That makes me feel a lot better about the project. I knew when I bought this rig that it was going to be a "till death do us part" Kinda situation. I wanna know as much as I can about this rig, but I just never planned on having to open her up this soon. I just bought this beast with 116,000 miles on it. Super clean. I drove it 700 miles home from L.A. And when I went to start it up the morning after I arrived home all I got was a "click hmmm". I was like, "are you f@&$ing kidding me?!" And the adventure begins......
Where would I be draining coolant from and how much is necessary?
