99 100 series
I was wondering if someone can help me out? I just purchased this cruiser and have just put a ARB bull bar with a 9000 series warn winch. I t has weighted the front end down alot.I tried to adjust the torsion bars, but was only able to get about a 1/2 inch out of it. My friend told me that ARB does make special torsion bars for this 100 series but not sure on this info? Does anyone have any suggestions? Are there any leveling kits for this?
The adjuster would bottom out pretty easy with OEM adjustment. You could get it to raise a bit more by reindexing the torsion bar. The spline key are just soft polymer that would easily removed using Philip screwdriver. You would need to remove the torsion bar and then reindex the spline one or two teeth.
Uprated aftermarket torsion bar are better on road since they give stiffer rate and would control the weight better. The only downside is price and max flex.
