- Joined
- Jul 7, 2013
- Threads
- 17
- Messages
- 65
- Location
- Rogers,AR/Buenos Aires, ARG
- Website
- www.tat4x4.com.ar
Hi there folks,
I've got a 98 LC US Spec and would like to be able to switch back and forth on the Exterior Temperature display between Celsius and Fahrenheit degrees.
I've read a couple of threads on this and I simply can't believe this cannot be done... In a fairly extensive research done here in a post from 2009, I found this picture where I can clearly see that the temperature indicated is in Celsius, and that the C is below the position where the F is seen on my cluster...
I am pretty sure this should be something rather simple to convert, yet cannot seem to find an answer on how to do this. Any leads? Where would I go on researching about this?
Thanks in advance,
Andres
I didn't read your comment but had the same idea !
here's the pic I found
But the only certainty is that the lcd display is the same... nothing sure for the electronic part behind
Thanks in advance,
Andres
