98 landcruiser abs code
Your brake light bulbs are out (49).
And possibly something fishy w the front left sensor (32), but fix the brake light first. The last one is battery voltage, but they might all be from the same fault.
Did you try to just reset the codes?
Can't check abs codes with obdII. How did you find out the numbers?
Try to do the sensor today, but it stuck on there, try to get it out and the plastic crack, do I have to take the break disc out to get it out, becaise the plastic still stuck. Thanks
