2.7L, 5MT, 80k miles
I've searched these forums for answers and have tried a couple things, before I jump into the deep end with buying parts, I thought that I'd bring my issue here 1st.
So a few weeks back, I noticed that it started to get difficult to put it into any gear, but more difficult for 1st and Reverse. Then it got to the point where it was damn near impossible to get it into 1st and Reverse, and still notchy for the rest of the gears. Got on Ih8mud and looked for similar issues.
I've checked the slave cyl fluid, and it's nominal. I checked the transmission fluid and it's at the proper level, I even put in a bit more to make sure it was at the bottom of the hole. No change. I'm led to believe that either the Clutch Cylinder is going bad, or it's the shifter ring under the shifter ... or maybe after 80k on the clutch and pressure plate, it's time for a clutch job.
Thoughts? Suggestions? Ideas?
