For Sale 92' fj80 transmission, t-case, axles, driveshafts. (1 Viewer)
KC, KS
I have the following parts for sale, prefer pick up , but will ship for $50 handling fee plus shipping (buyer arranges shipping unless we agree otherwise). Located in Kansas city, ks. area.
Automatic transmission (a440f) $225 starting bid on eBay
http://pages.ebay.com/motors/link/?nav=item.view&id=271366672163&globalID=EBAY-MOTOR
Transfer case $200
Front axle $350
Rear axle $250
Steering box $100 (sold)
Driveshafts $50 ea.
I also have a lot of other good parts feel free to ask if you need something that's not on the list. Thanks! Dale
how many miles on the steering box? I trust it's not leaking and the gears are tight?
Do you have the rear 3rd row seats? I would be interested in then and the front axle.
Wish I did. I scrapped the rear seats with the body. I do however still have the front axle. It will be ready for shipment tomorrow at the latest.
I still have the following parts for sale. If you need others don't be afraid to ask.
3fe Engine parts:
Engine wiring harness
Head
Thermostat housing
Smog equipment
Water pump
Fan clutch
Oil pump and pick up
Fuel injectors
Fuel injector rail
Belt tensioner assemblies
Belt pulleys
Valve cover
Alternator
Starter
Distributor
Intake manifold and sensors
Exhaust manifolds
Air filter (tuna can)
Complete transmission
Transfer case
Drive shafts
Front, and rear axles
E.c.u.
Main cabin wiring harness
Cruise control actuator
Various modules
Corner marker lights front
Door handles interior/exterior
Grey dash pad without cracks
Good grey passenger front seat
Ragged out drivers seat grey
Sunroof Complete assembly
Antenna (mast is broken at base but works)
Turn signal, headlights, wipers switch assembly.
10 oem aluminum 15" wheels (4 without tires)
Glove box (grey)
Ignition tumbler with one key and electronic components
Door locks (two front) and glove box lock matching set includes one key (no hatch lock).
Instrument panel (gauge cluster)
Mirror switch
Dimmer switch
Rear heater switch
THE BODY AND FRAME ARE GONE.
Thanks for reading! Dale
To the top
Was the tach working on the instrument panel? How much? Also, how much for the dash pad?
Yes, the whole instrument panel works, it's on eBay for $79.99 with free shipping (starting bid). I think $75 sounds reasonable for the dash pad, but shipping will likely cost nearly as much.
To the top
To the top
If you still have the trans and t-case can you call me at 509 703 0467 or pm me. Thanks
how much for the tuna can with the AFM???
how much for the engine harness and alt?
