'91 Hilux JDM 2.8 diesel - inertia switch/fuel cutoff
Middleburg, VA
Do these motors have inertia switches? This truck suffered a light roll over and was running for about 45 seconds before it was able to be shut off/stopped running. The motor is spinning over, but will not start. Before we get into other options, I was wondering if there is a fuel shut off. Don't think there were.
Thank you in advance.
Im guessing this is a 3L engine? It will have a fuel cut solenoid on the injection pump, it will have 2 or 3 wires coming from it. Sometimes the screw on top loosens up and causes erratic starting
Great. Thank you for the info. Good to know for sure. It is the 3L.
Again, Im assuming it has a rotary pump.
If its working correctly, you should hear an audible click from the solenoid when the ignition lights come on.
