Done!
Thanks for use of the tap, PJ!!
I chose to drill/tap at the angle for better tranny hump clearance when using the connector shown in the last pic; straight-on/vertical would've worked too, and would've been simpler (if i were smrter and just used simple right-angle insulated fastons).
OH! NOTE--for anyone else doing this--note that the shifter rod that actuates the switch is NOT solid and has a void that will leave your switch un-actuated while in reverse if you drill in the wrong spot... The pix don't show this, look closely for yourself or cram your finger in there & you'll feel what i'm talking about.
For the record
- 9/16"x18tpi worked great
- the 1/2" drill worked fine (vs. 33/64 recommended)-- the cast metal is very soft.
- i used teflon tape to help seal since the (hand-ground) seating area is imperfect
- reverse switch: Napa P/N NS6578 (two terminal acts as normally open SPST)
- standard GM 90-degree T-connector w/ series-56 faston (has locking tine for retention in connector)
Some pix for posterity...
