mike
82bj42 1st project
I have almost the whole vehicle available. It has the brown interior. Biege exterior. You can PM your parts needed lists to me.
Here is a brief list of some the parts I have for sale.
Fuel Tank complete with pick-up and sending unit-$175
Cooling Sytem Parts:
Radiator-$100
Radiator shroud-$35
waterpump with clutch fan with fan blade- $80
thermostat housing-$40
Engine parts:
mounts- engine- $60 Pair
Smog pump-$75
Air cleaner assembly-$30
a/c compressor $55
Motor Mounts-$50
Cylinder head complete with rocker arms-$250
push rods(complete set available)- $4 each,
head bolts (complete set)-$4 each
valve cover ---$30
waterpump with clutch fan with fan blade- $70
Power steering pump complete-$155
fuel injectors complete with fuel rail-$200
Intake manifold-$200
exhaust manifold-$80
engine block with pistons , crank shaft --$200
Transmission parts:
Transmisission with transfercase-$700
Shifter-transmission console with base plate-$40
Transmission mount-$30
Flywheel--$50
Torque converter-$150
Body Parts:
Seat- frt dr -$55ea
Seat Rear brown-$100
Hood-$150
Hood hinges-$30/pr
Hood balancers (springs)-$60/pr
glass for frt doors-$40
glass for rear doors(large)-$25
glass window cargo area-$35
Door -fuel filler(brown or gray) -$10 ea
Door Panels( interior brown) -$25 ea
Motor-windows regulator-$100
MasterSwitch-Drivers- power windows/locks-$100
Switch-power windows-$30
Glove box(interior box) -$15
Electrical parts:
Airflow sensor-$140
Wiring harness(complete) $100
fan-engine cooling-$30
fan-defroster-$25
ECU-Electronic fuel injection control computer module-$75
Radiator-$100
Radiator shroud-$35
Engine parts:
Smog pump-$75
a/c compressor $55
Motor Mounts-$50
valve cover ---$30
Transmission parts:
Flywheel--$50
Body Parts:
Seat- frt dr -$55ea
Hood-$150
Hood hinges-$30/pr
Electrical parts:
Airflow sensor-$140
fan-defroster-$25
