For Sale 88 Yota pickup, linked, locked, geared on 39.5 Iroks....
Hate to post this up, but have to sell the Yota. Truck is in Southington, CT. Asking $8,500, don’t need to sell, or pressed for cash, so keep your lowballs, and snicker offers to yourself! Not really looking for trades. I can deliver within reason for some $$$'s.
Frame/Body/Truck:
-88 Toyota pickup frame and cab, Titled and Registered in CT
-All pro tube bed kit
-Full Exo cage, no rolls on cage. Cage/tube bed built/installed by Ocean State Crawlers
-Warn xd9000i with 125 ft amsteel 3/8 rope in great shape
Suspension:
-Front is TG 3 link front with 12inch Fox Air shocks, no leaks, custom removable tube brace over motor. TG kit installed by Central Mass Offroad
-Rear is 3 inch Marlin crawler leaf spring with MC 4.5 inch shackles, and bilstein 5125 shocks. have traction bar (not installed)
Drivetrain:
-22RE with around 100k on the motor. Swapped in 22R intake, and converted to propane. Motor runs great.
-Got propane kit for toyota with 2 tanks, and mounts for 2 tanks on the truck. Built for offroading, not forklifts. Have two tanks.
-TG Rock Assault steering pump kit (1,450 psi pump, bracket, reservoir and cooler)
-Toyota 5 speed manual transmission out of 85 4Runner, clutch is good.
-Marlin Crawler MC07 10 degree Clocked Dual transfer case adapter, stock gears in front, rear t-case with 4.7 gears
-Tube transfer case, mounts to the frame in 4 spots (cant remember brand name)
Axles:
-85, full trussed front toyota axle, Marlin Crawler high steer, 5.29 gears, spool, long field 30 spline 4340 chromoly super set, ARP knuckle studs, ARP hub studs, ASIAN lockouts, TG rock rings, backing plate eliminator, full weld on diff armor, Hydro assist Ram, with custom mount (looks like a mount for a full hydro, due to space with 3 link, mount is beefy) Mount built by Central Mass Offroad
-Rear IFS axle with 5.29 gears, spool, full weld on diff armor, stock rear axles
Tires/wheels (no longer have the beadlocks that are pictured):
4 - like new 39.5x13.5x15 iroks (less than 8 trips on tires, never been on road) on 15x10 aluminum rim (last pic is of current rims)
1 - brand new 39.5x13.5x15 irok on 15x10 aluminum rim
Again, asking $8,500, and truck is located in Southington, CT. I can deliver within reason for some $$$'s.
10/18/12 - UPDATE...Also, thinking about parting it out. Let me know what your interested in, and if i can get enough commitment on parts, i will part her out. you can PM me, or email me at petzl21@yahoo.com
