- Location
- United States
88 SAS truck, $2500
For sale is a 1988 extended cab Toyota Pickup. It has a solid axle swap done to it using the 4” kit front and rear from trail gear. The solid axle was rebuilt when the swap was done less then a year ago. The truck has a 3.0 v6 in it with 190,000 miles on it and it runs well. The timing belt, brake master cylinder and crank seal were replaced at the time of the swap as well. Truck has 33” firestone destination AT’s on it with decent tread. The interior is pretty clean, has a kenwood head unit. This truck could easily fit 35’s + I just don’t have the money to afford this stuff right now and will be going to college soon. Stock 4.10 gears, no lockers. Does have the v6 rear end. The frame is solid. The rear half of the frame has been cleaned up and painted since pictures. A much nicer black bed has also been put on.
Problems:
-This was a wheeler so the body is a little rough but not to bad. Passenger side door is dented in.
- In 4wd because the angle of the drive shaft is so steep in the front it will rumble when you drive it on the street. Works fine on the trails. Easy fix would be a hi pinion front or dual cases.
- Could use a good alignment
It has a home built front bumper on it, will include a simple black tube rear bumper and fender flares.
Asking $2500, located in Wilmington, Delaware, Feel free to email me with questions at Chrisbreton17 at hotmail dot com. I wouldn't mind keeping the tires so if you don't want them we can talk about a lower price.
Pictures
Toypu87/Rausch Creek - Photobucket - Video and Image Hosting
-hate to sell this but my parents want me to get down to one truck before I leave for college
Problems:
Pictures
