Sad day. Driving home from skiing Mount Baker, my transmission went out. It was stuck between 3rd & 4th driving in and is now perpetually stuck in 1st or 2nd. This was a pretty sweet car with a lot of issues. I got it from Canada to convert to veggie oil, drove it to Alaska afterwards, wrecked it there, but it still drove just fine and then had it shipped back here. It in an 88 FJ-62 with an 83 BJ 3B diesel swapped into it. I made a homebrew veggie system for it that needs some work, but worked great on the drive up to Alaska.
Details:
Chasis: 88 FJ-62, 400-500k km. Metallic gray. Frame is rusting through on the inside channels. Body has some rust. Whole front end is warped from going into a pole sideways in Alaska. Interior is fairly nice. Doors are good with a little rust on the rear doors.
Engine: 83 Toyota 3B 3.4L 4cyl diesel. 150k miles (not km), had heads rebuilt 40k miles ago. Don't have compression specs on it, but it was able to accelerate slowly up steep hills. Put out some white smoke on start-up, but doesn't smoke after warming up a couple minutes.
Veggie system: Pretty basic, 2nd tank, line-in-line, heated filter, manual switch, all coolant-based heating
Tranny: 4 speed, not sure which one. Stuck in 2nd gear.
Transfer case: Manual 4H, 4L, 2H, N
Extras: 13-BT exhaust manifold for turbo swap, nice solid metal rear bumper, power steering pump & arm
This is in Seattle, WA.
Asking $3000, but make an offer, I need to get this moved. Thanks.
Details:
