Hi again. Wanted to get a better understanding of this transmission and if it need a rebuild or maybe better cleaning. 247K miles. The transmission (since I bought it 2 years ago) has a slip between 2nd and 3rd. I changed the filter and cleaned the pan about 10K miles ago.
ISSUES:
GOOD RESULTS: It shifts much more smoothly-- No clanging banging from neutral -- No cold weather hesitation --
Other Results: on heavy takeoff, it runs through the gears strong without any slippage, even uphill.---On soft take off, it still slips from 2nd to 3rd but not quite as bad. BUT if you are climbing a hill and it downshifts, it still almost redlines before you can get off the pedal.
Not being a transmission guy, I really dont know if this a dirty valve situation OR worn bands OR both. Common sense tells me 247K miles take a toll on any tranny. I want to avoid a rebuild (for a bit longer) Had a reputable Cruiser mechanic tell me also that the HARD parts for this tranny are getting harder to find if it need them.
Any thoughts or advice are welcome.
ISSUES:
- slips between 2nd and 3rd on easy start offs
- on uphill street climbs, it kicks down from 3rd to 2nd and almost redlines the tach
- bangs and clangs when put into gear from neutral with rpms about 750 or lower.(most times but not always)
- Slow to go into reverse with cold engine on cold days.
