88 62 Auto Tranny help!!!
Briarcliff, TX
Guys-
I'm in dire need of some help, direction, ideas, etc to get my Cruiser back on the road. The tranny shop has had it almost 2 months and they're about to give up...they're out of ideas. Please read below an email that the tranny shop wrote to Rodney for help. If you have any questions or need more info please don't hesitate to ask!!
Here's the email from the Tranny shop...
Hello Orto,
I work for a transmission shop in Austin Texas. We recently built this transmission for a customer. His original complaint was no torque converter lock-up, other than that it seemed to work fine. After our overhaul, it has 3rd gear starts. We installed a pressure gauge on the governor tap on the side of the case and pressure reads 0psi in Park, Reverse and Neutral. On initial engagement in Drive the gauge also reads 0psi but after take off, governor pressure climbs rapidly and will stay at between 20-30psi even after coming to a stop. The only way to get pressure to return to 0psi is to place the gear selector in something other than Drive. Problem gets worse as fluid heats up.
Seems like a leak to me but all valves in VB are free, TV cable was adjusted to spec and then everywhere in between, governor valves are always free, VB was flat sanded and is flat, no wear in rear case area where governor rings seal, new Teflon sealing rings on governor support (have also tried the originals once again just for good measure), no visible wear of governor valves or governor housing. We have had this in and out several times and we are out of ideas. We are thinking about replacing the governor housing and valves just as a last ditch effort to see if that changes anything.
The thing that bothers me most about this job is that all the governor parts, valve body and case are original. I would think that if it shifted out OK when the vehicle arrived that it should shift as good now even it there is wear we can't see. The builder on this job claims to have run into this problem on a few Cruisers before this one but since we do very few of these, can't remember the previous solution. I feel that if he's run into it before possibly itʼs something he is creating during the overhaul.
Your reputation precedes you and any advice or suggestions you might have are more than welcome. At this point we are also interested in pricing out a unit from you, should we be unable to resolve this issue for our customer.
:bang:
I'm assuming you haven't heard back, there's nobody better to ask about the A440F. I don't like to say it but you should have searched here before bringing it to a shop, the consensus is that nobody has much luck rebuilding them.
I just burned mine up and am going with a H55F (5 speed) instead of the automatic. Probably about the same cost as one from Rodney.
You're correct...I haven't heard anything back yet. It's a tough deal...I did do some searching, but the shop was recommended and has some prior experience w/ these trucks. You know how it is...I was headed out of town on a couple hundred mile trip when it happened. Next thing you know your truck is torn apart and you're looking at it on a bench. I need some possible things for the shop to try b/c we are running out of ideas in a hurry. They're going to try a different governor and hope that works, but they don't seem too confident that it will.
Have you looked at the information posted in the 3FE yahoo group? There is a lot of info there. I feel your pain. My trany clunks from Park to Drive and it's only a matter of time. :(
Your clunk is probably a t/case issue, not tranny. Do a search on McNamara gear.
Bill
If the shop can't get yours to work, and suspect a problem in the VB, I would encourage them to get you an Extreme VB from Rodney to make things right. I've had one in my truck for less than 2 weeks, and am quite happy with the change.
I ordered from Rodney August/2007 and there was no US dealer/distributor at that time... but it has been almost a year so maybe things have changed.
Pacesetter Products in Whitehorse, Yukon. They are one of the banner advertisers here on mud.
Thanks for the info on the US Dealer for Rodney's VB. I'm going to look into that ASAP if the shop truly feels that the problem is in the VB and not the Governor, line pressure, etc. The more I read and ask around it seems there is a leak between the VB
Do you happen to know a cost for the VB?
I ordered a McNamara Gear and have it installed in my tranny that doesn't work...it was a much cheaper/better way to deal w/ the "clunk" than buying the Transfer Case Gear and Shaft
Brad - just buy a new 5 speed, and I'll put that in my Fj62, and give you my tranny that is working great!! :)
Interesting...very interesting. I'm on the fence w/ doing something like that, but if I were to buy a 5 speed it's more than likely going in the blue beast. I like the way you're thinking though...
LOL!!
