87 FJ60 225K Miles. Compression tested 150 on all cylinders except # 4 which showed something like 15. Good oil pressure - no knocking. The engine ran well even with a dead cylinder. The head gaket was not leaking and I have no reason to believe the head is cracked. Valves and or seats in #4 are probably bad.
Parts or whole. Let me know what you are interested in.
$200 for the long block (valve cover to oil pan with the intake/ex manifolds) I will provide a price for any other parts requested. Ill just add a list with prices if there are requests to part the head and block.
The engine is partially disassembled with the head removed and #3 and 4 pistons/rods pulled out. The cylinder walls look good and may do fine with only a honing.
Just about everything under the hood is available including smog parts and the carb (carb was just rebuilt with a basic parts kit and a new float).
Engine also has a new fuel pump and new oil pressure sending unit on it from PO.
We were going to rebuild, but will be doing a 3B conversion instead.
Thanks
Chris
Thanks
Chris
