- Location
- United States
Bought an 86 turbo (22TRE) pickup to part out. It hasn't been run in two years (frame is broken). Mileage appx 125K. Engine runs well, had a new timing chain not long before the frame broke. This has an automatic trans that shifts well. While I will list the major parts for sale here, if the engine doesn't sell as a unit I will part out the various bits and pieces. Truck is in northeast PA not far from Rausch Creek. Here goes:
Cool bed mounted rollbar has a finish that looks like aluminum $100
"Turbo" embroidered (factory) tan seats $100 the pair Real nice door panels $50 the pair
Transmission and transfer case $200
Front diff $100 Rear axle complete $125
Engine complete with turbo, water pump all frotn end parrts, starter and alternator $500
ECU $75 Front driveshaft with double cardan joint $50 Tail light assemblies $15 each
It also has a dual gas tank setup- both fill from the same filler neck $100 for the setup
Power steering box $65 Aisin hubs $60 the pair Calipers and rotors $20 each
Also from my turbo parts stash have an 87 engine with a bad bearing $100 (complete with head)
A non-digital full gauge instrument cluster from a 5 speed turbo truck $65
A non-digital full gauge instrument cluster from an 87 (I think) auto turbo truck $65
If you want anything specific ask. Best to email me shmukter@pa.metrocast.net.
