86 Toyota 4x4 Deluxe - $900 obo.
San Diego County, CA. This truck has been modified over the years, and has body damage from being beaten on the rocks. The bed has been bobbed almost 2 feet from the original long bed, and a 3" body lift is instaaled. You can run 33s on it no problem in it's current configuration. THIS TRUCK WILL CLIMB WATERFALLS!!! The truck has power steering, power brakes, A/C that works, tilt steering, 5-speed trans, and selectable hubs. I just installed a brand new stainless steel muffler tucked under the bed where nothing can snag on it. The engine runs great, and has about 150,000 on the original engine and about 10,000 miles since the top-end and timing rebuild. ALL engine gaskets were replaced, so it doesn't leak much. Front IFS has 4.88:1 gears and powertrax locker, Rear diff has 4.88:1 gears and full carrier Detroit Locker ($500 plus unit!!!). 3-core Radiator is about a year old. Trans and TC are tired. Rear diff pinion gears are stripped. You can drive it home with the front axle engaged. It is currently registered and smogs easily. Tires are 31x10.5R15. Bucket seats are out of a Corolla. The truck has served me well and took me to Moab where it performed exceptionally. It needs someone to put new gears in the rear dif and it will be ready to go anywhere again. The pics are from months ago, and the tires and a few things are parted out, but the truck is primarily in the same condition as in the photos. First person with cash takes it, and I can help deliver it locally. Call me for a faster response.
pics here:
http://s75.photobucket.com/albums/i291/robphotobucket_2006/1986Toyota4sale/
Rob 619-709-0759
