- Location
- United States
my craigslist add in toledo ohio
im in port clinton oh
for pictures go here
Picasa Web Albums - 11169569020068173... - 2010-08-28
I have 3 toyota pickups that I am selling whole or parting out. Please ASAP if you want a whole truck
First is the blue 1985 toyota std cab 5spd 22r long bed that I am currently driving. It is very very rusty including frame rust but it runs well enough that I am driving it to work and also hauling scrap with it. Make Offer for this running truck... Fuel lines need fixed. the return/vapor lines leak. this truck has plates and a clean title in hand.
Second is a red 1989 std cab reg bed 4spd 22r with the motor completely removed and almost bare block on an engine stand. 90 % of the accessories are still with the truck. The body is in solid shape with faded paint. This was a southern truck from Louisiana and the frame and bed are much better shape than many similar year trucks around here. the frame has surface rust but is solid... clean title in hand
Third is my red 1985 diesel xtra cab 5spd with 2L diesel with no bed. This truck starts and runs and drives around but it is smoking due to low compression in #3 cyl I believe. I put new glow plugs in it and pulled the injectors and had them pressure tested (pop tested) and check for spray pattern and cleaned. the injectors are fine. I believe it is rings or valve seating causing about 100 psi less in #3 cyl. The truck is a Canadian vehicle that was bought as a parts truck intended for a engine swap. there is no title and from what I found you are not going to get one for this vin #???
There is one aluminum truck cap for the std bed this will be sold seperate
also one aluminum tool box that fits Toyota and other import small box trucks like s10 Tacoma b100 Mazda ranger etc. this will be sold separate its in great condition.
Make offers on these
Cash is preferred but I'm open to trades of
Newer Snow Blowers with 7hp or more
Newer jet skis with trailers
Newer travel trailers nicer pop up campers that don’t leak!
Trucks or cars
Autoloader Sh0tg()ns or handG()NS … yes I call in to check to verify…
Enclosed work Trailers
Short shaft Outboards 15-40 hp
Please email back your phone number and I will give you a call or I can email.
Trucks or cars
