21 in HG vacuum,no exhaust restriction,hooked up fuel pressure tester and lost pressure after about 15 min.If the injector is leaking it is very slow(i am thinking that it is the check valve in the fuel pump now)I am starting to think that it is running lean under load condition.At idle the voltage reading off the O2 sensor fluctuates from 1 volt to .2 volts consistantly so I know the system is working properly at idle but that doesn't mean I am not lean under load.Besides a leaking injector doesnt really hold up to me because bosch CIS(constant injection) cars constantly inject fuel throughout the revolution cycle and my volvo never heats up the exhaust.Besides I would have to be dumping a lot of fuel into the exhaust cycle for that to happen causing drivability problems, and it would also throw off my O2 sensor than at least I think.I am going to buy an air/fuel ratio meter and hook it up and see what happens.Back to driving my trusty VOLVO again.
i was not sure about what type of injection system a 22RE uses. so i asked a reputable Toyota certified Foreman. he says that the engine does not use CIS. and that it does use MPI. also that the injectors are not made by bosch, but are bosch style.
according to your O2 results, it is within proper operating perameters. but tell me if it fluctuates 8 or more in 10 seconds. if it does, then good.
the second place to look is the valve adjustments. accoring to the foreman, not only can a leaking injector cause this but a too lean or too rich condition can cause this.
incorrct valve clearances can cause either or.
also spec out your coolant temp sensor and you air intake tempo sensor. (housed in the AFM)
if you do not have values, i will scan them for you.
back to the CIS/MPI thing, part of your description resembles my FSM description, maybe this is where you got it wrong
"Each injector inject at the same time, one half of the fuel required for ideal combustion with each engine revolution"
now just from analizing this statment is sounds like that is what would be considered CIS, but again accoring to this foreman, it is in fact MPI
