84 toyota ex cab w/exo cage
this is an 84 toyota ex cab project i have been working on. new items are..37" iroks, wheel spacers, front calipers, master cyl., 15" travel pro comp shocks, marlin crawler shock mounts, all pro e-brake, 9500lb winch, 8" pro comp lights, rock lights, exo cage, front downey 3" springs, rear downey shackles, and a marlin crawler front axle knuckl rebuild kit w/ wheel bearings. truck has about 7" lift, header, weber carb and a welded rear end. i also have an extra t-case for a doubler. truck needs a new throw out bearing..(squeals), new thermostat or radiator..(ran hot last time out), and the tie rod has a slight bend to it. i would also put some lower gears in it for the size tires its running. im located in bellingham washington...looking for 4000 obo or possible trade for a street bike...or maybe something else??
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
