- Location
- United States
Forsale:
1984 FJ60
Overall Description:
Purchased in Montana and drove 1500 miles w/o any issues. I have done alot of work since then and what you have is a solid truck. No suprises. If you have questions do not hesitate to contact me.
The truck runs great and I drive it every where. It has COLD A/C. This cruiser runs down the road without a wobble, shake, or shimmy. Truck runs cool and there have been NO over heating issues. It is truly ready to pick-up and drive. I have never had one issue. Truck starts with no issues and idles great. Cold A/C makes it a pleasure. The Previous owner spend 2k on full tune-up back in Nov. 2006. 4wd works great. Tranny shifts smooth, no grinding or wining. Shifts through all gears smoothly, 4HI and 4LO work great.
Asking $2000
Miles: 189,XXX
Clean title in hand. bring cash and drive away happy!
PM me if you have questions
Here is a break down of work done and description
Suspension:
OEM HJ60 Fender flares are also included a $600 value!!!
Have records going back to Orginal owner.
This is a solid truck. PM with questions. here are the photos:
1984 FJ60
Asking $2000
Miles: 189,XXX
Suspension:
- new shocks
- steering stablizer
- allignment
- Tires have 5000 miles and are like new
- all wheels balanced
- rebuilt driveshaft
- new clutch
- resurfaced flywheel
- replaced rear main seal
- new slave and master cylinder
- new fluid through out (diffs, tranny transfer etc...)
- rebuilt front end - (From CCOT)
- new seals
- new bearings
- New brakes front and rear
- new brake hoses
- new rear brake cylinders
- rebuilt parking brake - (works great!)
- Rebuilt OEM carb - runs and starts like new!
- new radiator
- new belts
- new fuel pump and spacer
- working Carb fan (very rare)
- new choke cable
- new oneway check valves
- Power steering pump - no leaks
- working smog pump
- new plugs, wires, distributer, pcv, Full tune up
- Ice COLD A/C - A must in FL
- replaced all o-rings
- oil
- flushed and charged
- Fuel system flushed and cleaned
- new drier
- Had compression test and all were around the same. will see if I can find results
- new Drives side seat foam
- new (used) DS seat fabric
- very few stains
- rear cargo area has some singed carpet
- is nice for age
- OEM AM/FM stereo - works great
- All windows work with the exception of the rear DS window. The plastic wheel that rolls up and down is broken. easy fix
- very little rust
- started body work and is a few hours from being ready for paint
- replaced both front fenders
- welded right rear quarter panel in place.
- filled with bondo is ready to sand and prime
- solid weld
- lower lip of tail gate has some rust
- DS lower lip of door has some surface rust
- front window has spider crack on PS side. Does not impare view.
- both bumpers are bent but still in good shape
- still have all plactic trim, end caps etc...
- Frame is solid and has very little surface rust.
- no frame rot. a little POR-15 and many more years to go
Plus we are planning on starting a family so a more mall friendly cruiser will be in order.
