BigSur said:Hold on there tonto!! They are two different carbs. The 87' carb is slightly different then the rest of the 60's. I know this cause i have tried to put a 87' carb on my 83' and it DID NOT WORK. Look at your 84' carb and compare it to the 87' and you'll see a slight difference.
jason
Yes, it is a direct swap. All 81-87 2F carbs are interchangeable.loeky said:can someone clue me into whether it would be a direct fit for a stock carb from an 84 into a 87? anything different between those years?
thanks in advance.
They sent you a 79-80 carb.BigSur said:There are different emission parts on a 87' carb that a 84' won't have. When i tried to put a 87' onto a 83' truck i forget which one it was but i had an extra pipe, hose, something that was left over so i ended up putting the old carb back on. I talked to one of the guys at cruiserparts.net (where the 87' carb came from) and asked him if a 87' was different then a 83' and he said yes and that's why it didn't work.
FJ40Jim said:Yes, it is a direct swap. All 81-87 2F carbs are interchangeable.
The PN is 21100-61142, BTW. That will tell you if you have *the* 81-87 carb.
