- Location
- United States
The engine has 306000 miles, 24 volt, power steering, out of a 1984 60 series.
The transmission MAY be an H41 (still to confirm gear ratios), transfer case is manual shift.
all prices are suggestions in USD, plus parcel postage from N1E 3E6 Canada
Please feel free to make reasonable offers...I'm more interested in seeing them put to good use than to hold out for absolute top dollar:
-Rocker shaft and arms - $200 (2 arms have moderate wear at the valve interface, one has significant wear at the valve interface, the rest look great)
-Head with valve gear, with or without the rocker shaft and arms (if not already sold), with or without intake/exhaust manifolds - I'm happy to get it crack tested at cost - $500
-injection pipes - in great shape $200 set of 4 *sale pending*
-Injection pump - $250 *sale pending*
-Power steering pump and pulley, plus bracket if needed - $250 *sale pending*
-24v Alternator and pulley, plus bracket if needed - $175 (vacuum pump negotiable)
-24v starter - $175
-Short block, includes pistons/rods/crank still installed - $150
-Oil pan - $100
-Flywheel with used clutch - $50
-3B fan shroud - $50
-manual transfer case, with new bearings and seals - $150
-vacuum assist clutch master cylinder, complete with mounting bracket, hard line, flex line and clutch slave - $100
The transmission MAY be an H41, but I've still to confirm this - let me know if you're interested and I'll let you know once I've confirmed.
I'm happy to send you pictures; please email me directly corvidesign1@gmail.com
Pete
-24v starter - $175
-Oil pan - $100
Pete
