I am making progress....slowly but surely. Here are some shots of the rebuild work on the 8274. Everything was disassembled, washed in the parts washer, then blasted with magic skat (crushed glass). The painted parts got 2-3 coats of nason primer, two coats each of urethane paint, then 2-3 of high gloss clear coat...over about 6 days. The grey coat is something like a metallic gray, from a mitsubishi montero book...I should post the paint code.
The motor housing is painted with SEM high gloss rust inhibitor. The winch line drum got the same paint. It is hard as hell and will resist rust over time.
The motor housing got new brushes.
I should be reassembling later this week.
how did you like the needler?
