For Sale 80 Series OEM Front Axle Rebuild Kit
Akella
London, ON Canada
3 KITS INSTOCK
It includes only OEM Parts. Bearing can be chosen as OEM or Koyo aftermarket.
SEAL, DUST (FOR FRONT AXLE HUB) 90313-93003 x2
GASKET, KNUCKLE SPINDLE OIL RETAINER 43436-60011 x2
GASKET, KNUCKLE SPINDLE 43435-60020 x2
SEAL SUB-ASSY, STEERING KNUCKLE OIL (KIT) 43204-60032 x2
GASKET, FRONT AXLE OUTER SHAFT FLANGE 43422-60060 x2
SEAL, OIL (FOR FRONT AXLE HUB) 90311-62001 x2
SEAL, TYPE T OIL (FOR FRONT DRIVE SHAFT) 90310-35010 x2
WASHER, FRONT WHEEL ADJUSTING LOCK 90215-42025 x2
WASHER, CLAW (FOR STEERING KNUCKLE WASHER) 90214-42030 x2
RING, SHAFT SNAP (FOR FRONT DRIVE INNER SHAFT OUTER) 90521-34005 x2
RING, SHAFT SNAP (FOR FRONT AXLE HUB), T=2.4 90520-31007 x2
GASKET, DRAIN 12157-10010 x2
TUNION BEARING(FOR STEERING KNUCKLE ARM)90366-20003 x4
With KOYO Trunion bearings $210 USA Shipped
With OEM Trunion bearing $235 USA Shipped
Wheel bearings are available OEM and Koyo as well.
KOYO Aftermarket 2 INNER and 2 OUTER Wheel bearings $82.12
OEM 2 INNER and 2 OUTER Wheel bearings $152.64
I would get rid of the shims. Very rarely do you need them. You always jut end up reusing the ones already in there.
I would add 12157-10010 (x2) and 90214-42030 (x2) to have a more consumable-useful kit.
Pm incoming
I might need this down the road...
I am interested in the kit. Anything additional you would recommend? (Spindle bushings)
Still available? I'd like to get a kit with OEM bearings.
Hello,
I am interested in one kit including spindle bushings and oem bearings.
Do you know how much is shipping to Romania the cheapeast way possible?
Hello,
Pm sent
How much for a complete kit plus wheel bearings and front rotors, OEM for my 91 hdj81? Could pick up as I work near london.
Thanks.
Thanks.
pm sent
