I am setting up a small group buy for some CNC machined aluminum transfer case shifter knobs for 80 and 100 series. The 80 and 100 both have the same shift pattern and thread pattern, so they are interchangeable.
For those running a body lift, he can make the knob so that instead of sliding over the shaft (like the OEM knob) the entire knob would be solid and the bottom would have a hole drilled and tapped for the shaft. You would then have jam nut on the bottom with the knob on top of that, you use this to set the position of the knob so that it is oriented correctly. This will raise the bottom of the knob up about an inch or so. This would be ideal for if you wanted the knob to sit up a little bit higher for clearance to the console. Just from taking measurement, it would probably be plenty for up to a 1.5" body lift.
Welcome to Ellisprecision.ca
^^^This is the shop that make them. He (Joel) has been making custom battery clamps, grab handles, and shifter knobs for the FJ Cruiser crowd for a few years now. His products are top notch.
You can pick from any of the following colors as well for you order. If you click on the color it shows you a picture of a battery clamp anodized in that color.
The price is $49 +$12 shipping (from Canada).
We need at least 5 people to make this group buy happen, but he will make a few more than the group buy number for any late comers.
If you are interested, please PM me with your full name, email address, and what color you would like your transfer case knob in. I'll give it about a week or so and then email Joel the order list so he can get started.
If you have an 03+ with the A750 transmission, than the transmission shifter knobs he makes will also work. I included a picture of those at the bottom.
I talked to him and sent him pics of the 98-02 shifter, he said he just does not have the time to design and test that shifter right now, sorry.
Order list:
1. LJ_24 - (2) black TC
2. RTB falcon - (1) black TC
3. Anthony.L - (1) black TC, (1) black transmission
4. Bull Moose - (1) black TC, (1) black transmission knob custom engraved (TEQ)
5. Cruiser couple - (1) black TC
6. pgmatt - (1) black TC
7. phrogg4evr - (1) black TC
8. shfd739 - (1) red TC
9.
10.
The dimensions for the TC knob are:
Height: 55mm (2.16")
Diameter: 48.5mm (1.91")
Necked down diameter (where the shift pattern part is): 35mm (1.4")
Here are some installed pictures from my 100 series.
Some of the transmission shifters. He can also do some custom etching into the top. I have seen a few folks get TRD, Toyota sombrero, and a few other designs. He can do something totally custom, though it costs a little more and takes a little more time to make as he has to recreate the design for his CNC machine to make. These are very simple to install, they simple screw on.
Order list:
9.
10.
