Build 79 Aussie BJ55 build
80 series door seals will do the job..
i.php
i.php
got the rear barn doors adjusted, central locking wired and tested and moisture barrier+door card on one door... fiddly stuff but needs to be done.
so today i ripped off the bandaid... i was using the pig to pull a round of hay out of the trailer when it decided to keep rolling into the barndoors..
i.php
luckily it mostly pushed out so i didnt have much to cry about. the life of a farm truck hey.
i.php
then for some reason today felt like the right day to clean up the shed.. it had been a bit of a shamozzle and now i dont have doors, bonnets and fenders laying about i could make i little more room..
i.php
had some company too
i.php
ended up with room to swing a cat
i.php
more pottering this afternoom saw the child seat anchor points installed and i finished installing the door cards.
unfortunately the astrays in the doorcards for the 2nd row interfere with the central locking so ill need to mod them to suit.
Ive got the engineer coming tomorrow to do an inspection and managed the day off work today to button up a few last minute things. fingers crossed ive got everythimg covered.
Right on, we are pulling for you!
in the last day or so ive
- front bar on
- mud flaps
- door cards, window regs, arm rests on
- license plate light wired
- park brake indicator fixed
- blower fan switch wired
- windscreen washer bracket fabbed
- handbrake cable backet
- all fuel and return lines secured and to length
- replacement filler hose installed
- fuel tank breathers hooked up
- drivers door now closes
all left to do is
- replace pesky heater hose
- re gasket thermostat top housing, thread tape senders
- bonnet back on
- power steering line to res and bleed
- install kiddy seats
- test
mudflaps
i.php
i.php
front bar
i.php
You'll be fine. I've been wondering if I'd need mudflaps for a RWC, every 55 sales brochure I've seen they're missing.
yeh i wasnt sure but not in a position to argue the point either.. so on they went. they will help keep muck out from under there though
That rear body mount is just a ledge that I am convinced Toyota put there so you could take home souvenirs from the trail.
Do you have a part #? Was it different for each door?
Thanks
No part number and yeh they are off each door of my donor 80 series.. so 2 front doors and 2 rear doors..
I've done as much as I can before engineer arrives..
i.php
checking for clearance with the sway bar and sump plug:
i.php
i.php
i.php
i.php
i.php
i.php
Had a good session with the engineer. There were no show stoppers and the only things left to follow up are:
- install a tyre placard from the 80 series, or get a copy made.
- find some ADR30 emissions stickers for the 15B-F
- confirm if the indicators have a failure mode when one or more incandescent bulbs blow.
Thats pretty much it.. stoked!
